Thread: M96 crank
Old 12-10-2024, 01:59 PM   #7
JFP in PA
Originally Posted by Bebbetufs View Post
Some people claim these cranks can't be ground because the hardened layer is too thin. Did the machinist test the hardness of the reground rod pin?
I just measured my own crank and found 0.0012" / 0.03mm runout. I was told by LN engineering to throw it away. It seems strange to me that the tolerance is that tight. The 944 crank has a tolerance of 0.0031" / 0.08mm. The 2JZ has a tolerance of 0.0024"
Have you measured the runout?
What tolerance did you use for the bearing clearances?
If I were you I'd have both cranks checked before continuing with the build. Also the carrier bearing saddles should be checked, just to be sure.
LN is correct.
