Some people claim these cranks can't be ground because the hardened layer is too thin. Did the machinist test the hardness of the reground rod pin?
I just measured my own crank and found 0.0012" / 0.03mm runout. I was told by LN engineering to throw it away. It seems strange to me that the tolerance is that tight. The 944 crank has a tolerance of 0.0031" / 0.08mm. The 2JZ has a tolerance of 0.0024"
Have you measured the runout?
What tolerance did you use for the bearing clearances?
If I were you I'd have both cranks checked before continuing with the build. Also the carrier bearing saddles should be checked, just to be sure.
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
