Thread: M96 crank
Old 12-05-2024, 02:16 PM   #2
Homeoboxter
There should not be any tight spot. Make sure you torque the bolts to spec and in the correct sequence. If still there is a tight spot, disassemble the unit and re-inspect each part. Did you replace the thrust bearing? The endfloat also should be checked.
