Old 11-20-2024, 11:00 AM   #10
TTGator
Originally Posted by randyzimmer View Post
I'm in the process of taking mine out while still in the car and have a couple questions. #1, the round wiring plug near the flywheel with the 90 degree boot on it. Is there a lever or something I need to press or twist? #2 I'd like to know wich is more painful, getting the air out of the cooling system or dealing with the trans.oil from removing the cooler and tying it up..
Great! We can get some confirmation
If it's the sensor I think you're talking about, there is a small bolt you have to remove then it just pulls straight out. No twisting or levers.
If you have a vacuum fill device for your coolant (which you should, I have a video on how to use and link from Amazon), that is easy. As far as the comparison between that and the trans oil, I don't know...
Keep us posted with it all!
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
