Old 11-20-2024, 03:57 AM   #12
spinjockey
Originally Posted by bigbuber View Post
Interesting development in the comments above lol
Anyway, thanks everyone for the help. I am replacing the pump, thermostat, and tank.
If this helps anyone, here are the links (delete the spaces) for all of the OEM cooling system related stuff and where I found it cheapest with shipping:
Reservoir: ht tps://porsche.oempartsonline.com/oem-parts/porsche-reservoir-99610614708
Cap: ht tps://www.fcpeuro.com/products/porsche-radiator-cap-911-boxster-cayman-por-99610644704#fitment
Pump: ht tps://www.fcpeuro.com/products/porsche-engine-water-pump-911-boxster-11243008314#fitment
Low temp thermostat: htt ps://www.fcpeuro.com/products/porsche-thermostat-wahler-99610601359#fitment
Drive belt: ht tps://www.pelicanparts.com/More_Info/99610215168.htm?pn=996-102-151-68-M216&bc=c&SVSVSI=0785#kitsComAnc
Should save you a few hour of googling
At equilibrium with the thermostat wide open, the engine should run at the same temperature regardless of low or high temperature thermostat because the thermostat does not continuously cycle open and closed. However, cylinder 6 is the furthest away in the circuit so runs the hottest compared to cylinder 1 in general. The engine oil cooler is also at the same furthest point just above cylinder 6. During warmup, the engine is developing hot spots. The low temperature thermostat helps limit any overheat scenario during warmup.
When the thermostat doesn’t open completely or correctly because of failure, you will get an overheat condition same as when there is a water pump failure. The engine develops relative hot and cold spots with hot spots being dangerous for engine component wear.
spinjockey is online now   Reply With Quote
