Old 11-19-2024, 07:46 AM   #9
Starter986
1998 Boxster Silver/Red
Originally Posted by theiceman View Post
your first noise was the pump bearing.. your pump is toast replace it. This would be a good time to replace the stat with the LN engineering one that opens sooner and allows the engine to run cooler. .
Prove it. "... allows the engine to run cooler... for a few minutes until operating temprature is reached.
Or... does it open earlier to allow cooling, sooner, on the rearmost cylinders? (Hint: Yes).
Math and science, only.
Lets get it on.
Installed low temp on my 98... in 2017... engine reaches same operating temperature... wait for it... same as OEM part. Yes, I have a Durametric... and an S oil cooler.
I'm comforted knowing the thermostat opens earlier... and takes just a few more minutes to reach "operating temperature".
Now.. if there is an aftermarket part that will reduce the [B]operating temperature[/B]... share. Emphasis on "operating temperature".
Please, no democrat math or science.
1998 Porsche Boxster
Starter986 is online now   Reply With Quote
