Originally Posted by 997_986
It's a 00 2.7. Sure with te the air pump? It only operates after the start to accelerate temperature of the cats by adding air to burn fuel, it only should operate with a runnung engine?!
Interesting! Maybe I can control that pump with a durametric, it's possible with the 997 (MK1). Will report back!
Yeah, I’m not convinced it’s a pump, the noise pitch changes and pops sometimes as well regardless of if the engine is on.
Check out the noise changes in response to my pumping the pedal:
https://drive.google.com/file/d/1GVC2V9df_spYfXuGWeOODGUdB-kYcJ6v/view?usp=drivesdk
I’m thinking it might be somehow related to a worn light switch assembly that may need to be replaced or poor stereo grounding or radio interference
