Thread: Wheel studs
Old 10-25-2024, 08:31 AM   #10
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by theiceman View Post
i guess he doesnt realize this car does not use studs and lug nuts , they use bolts. he will realize it as soon as he spins off the first bolt lol.
And since the hub is threaded and designed to hold a bolt, i'm not sure how he is going to install press in Studs if that is his desire.
I guess what his real question is, with the standard bolt, how far does the bolt threads extend past the hub face on the inside of the hub ?
I think that You misunderstood the question. Screw in studs are a thing and lots of track car Boxsters use them.
https://www.ecstuning.com/b-rennline-parts/competition-wheel-stud-conversion-kit-45mm-45mm-r14/ls064545r14~rel/
The answer will vary slightly depending on which wheels and which brand of stud. Mine have a significant spacer, so I didn't have an easy reply.
