Old 09-26-2024, 06:17 AM   #10
JFP in PA
Originally Posted by LoneWolfGal View Post
JFP, I ran across this alternative by European Parts Solution that EPS says "will last the lifetime of the engine":
https://www.europeanpartssolution.com/ims-bearing-upgrade-kit
Also available at Amazon:
https://www.amazon.com/Porsche-Intermediate-Permanent-Retrofit-Pressurized/dp/B00H8XH9ZQ
Like LN's IMS Solution, it's supposedly a permanent fix. According to EPS: "The bearing is completely submerged in oil thus not requiring the Pressurized Oil Feed Mod." A slotted shaft in the oil pump provides constant oil feed to the bearing.
At $679 it costs significantly less than the IMS Solution.
What's your take?
I have never been a fan of IMS roller bearings. Contrary to what they advertise, they are not stronger than the ball bearing design, and by far one of the biggest problems in bearing failures is heat buildup, and roller bearings get much hotter than ball bearings. I also cringe at how they want to get oil to the bearings............
