Old 08-11-2024, 01:01 PM   #1
N227RV
Windstop latches right and left - installed today
I installed new wind stop latches, right and left, on my clear windstop today. One latch was broken, the other 20 years old, so I decided to go with a new one. The new ones are an improved design. To top it off, there is a service bulletin that tells how to do it. For the record, these are part no. 986-561-737-01-01C and you have to specify Right or Left when you order them since there doesn't seem to be a part number specific to R or L. The new latches turned the loose and rattly windstop into one firmly planted in place. I'm going to try to attach the service bulletin, which makes it very easy to pop the old ones out. If you're struggling to get the old one out of the windstop, then you're not doing it right. It pops out easily. The new latches snap in.
File Type: pdf TI 6847 2-04 Windstop Locking Lever.pdf (82.5 KB, 279 views)
N227RV is offline   Reply With Quote
