Old 07-30-2024, 07:57 AM   #2
Magdaddy
The Retrofit Lab in the UK, makes lighting upgrade kits, I installed the bi-xenon projector kit with LED high beams in my 03 Boxster. Car came equipped with OEM xenon’s. Kit was super easy to install, and the lighting output is stunning. Very reasonably priced kits, and great responses from questions asked to them.
Regarding the lenses discoloration, I’ve used the Sylvania headlight restoration kit multiple times with great results. Will only last a few years for a daily driver, but obviously longer with less exposure.
Check out those Retrofit Lab options, you won’t be disappointed.
You mentioned that you want OEM…those headlights are likely $1k a piece. Quality modern aftermarket options are best…think 2008 lighting tech vs 2024 tech.
Good luck
Magdaddy is offline   Reply With Quote
