Originally Posted by anatolewilson
You’re correct that there's typically one fuse for the power windows, but it's still a good idea to check it. The fuse for the power windows is usually in the fuse box, and on the 2000 Boxster, it is often the D1 fuse. Verify the fuse is intact and check for continuity using a multimeter.
No luck. Checked for continuity and while I was down there checked all the fuses.
Is there a way I can manually put the window up until I can break the door down and check the window motor?
I live in Miami and its that time of year, daily showers.
thanks,
