Old 07-04-2024, 09:32 PM   #3
theWalkinator
You can zip tie it to either the mounting bracket or to the intake manifold, but if I were you, I would just remove the vacuum reservoir out of that place secure it somewhere near the SAI pump and run a vacuum hose from the Y connector to it, make it a lot easier to replace next time if it went bad.
theWalkinator is offline   Reply With Quote
