Old 06-20-2024, 03:36 PM   #1
Gmontg02
Not cranking after replacing starter, starter relay and DME relay.
First off let me start by say this forum is awesome and very informative. The people on here that contribute and advise are great. I have a 99 986, I started the work replacing the water pump, thermostat, thermostat housing, idler pulleys and belt. I filled ther reservoir and went to to crank the motor to get the air bubbles out of the system. I got a not start, no crank. I have since installed a new starter, starter relay, and DME relay, still not cranking. I pulled the driver seat and saw some corrosion on the ground post for the anti-theft unit. I cleaned The ground stud and associated ring terminals. Any insight would be much appreciated.
Gmontg02 is offline   Reply With Quote
