Old 06-02-2024, 01:47 PM   #16
spinjockey
I had this problem with a loose heat shield on the gilette pipes (secondary cat). A stainless steel zip tie looped around and through the loose shield fixed my problem. The heat shield may not be obviously loose but any ability to twist the shield while cold is an indication that you could have a rattle under other conditions.
spinjockey is online now   Reply With Quote
