Old 03-23-2024, 04:36 PM   #1
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by elav View Post
Before I realized that you can simply buy the $15 ignition switch part, I had bought the entire assembly. Honestly, replacing the entire assembly was a bit time consuming but easy. Perhaps do it this way to get easier access to the ignition switch part?
It's possible I'll end up replacing the entire assembly -- the $15 switch and the mechanical steering lock, which costs considerably more (although eBay has a choice one for $39.99). I hope the electrical switch solves the problem, like it did for several other folks. Although it happened only a couple times out of maybe a thousand, the switch froze solid in the "off" position, and it took a lot of fiddling with it and swearing at it to unfreeze it. Only a couple times, but it's enough for me to order a $15 switch and install it, the contortions required notwithstanding, and hope to hell it takes care of the problem.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
