Old 12-31-2023, 09:34 AM   #1
NotthatJake
Smile
Originally Posted by tommy583 View Post
I have a 98 with the 2.5 motor. I already installed the larger throttle body from a 996. I think the T on the 2.5 is the same size as the 3.4 T in the 996. It bolted right up. The throttle body from the 2.5 is the same OD as the 3.4 TB, the ID is the only difference. So what i'm saying is I'm not sure if the IDP would make a difference on my car or not. I'm pretty sure it wouldn't make an $800 difference. Maybe on a 2.7 of 3.2 it would?
Can you help me know where you found your larger throttle body? I can’t find the correct one and don’t have a part number to reference. I have the ipd plenum but can’t find the cable throttle body needed to bolt up to it.
NotthatJake is offline   Reply With Quote
