Old 12-28-2023, 09:22 AM   #1
Danimal
Anti-seize on engine mount brackets?
I am getting ready to replace my engine mount and I am wondering if I should use anti-seize on the bolts that attach the mount to the engine and chassis. Most of the write-ups mention using loctite on the bolts connecting the bushing to the chassis bracket, but don’t state if you should do anything special with the other bolts. Since just about everything seizes up under this car, I thought maybe some anti-seize would be a good idea.
Any thoughts?
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
