Old 12-24-2023, 05:44 PM   #4
joeta4
I installed this tonight.
FIrstly, the lever needs to be taken out of the blue assembly and rotated, the lean should be away from the driver.
second, this lever has a longer bottom shaft which requires you to remove the green shift assembly floor plate to provide the required clearence.
Attaching the c-clips can be a real PIA. but work with a partner to apply pressure and slip the clips in.
lastly, I didnt have to remove the forward-most bolt. If you do this install with the top down you should be able to pitch the center consule vertically in order to re-seat under the bat-wing.
joeta4 is offline   Reply With Quote
