Old 11-06-2023, 06:26 AM   #4
Burg Boxster
Originally Posted by TheRev View Post
Looking to see if it's possible to replace just the leather boot on my 986 emergency brake handle. See pic. The leather ripped down at the base. I've searched online to no avail and contacted Suncoast parts and they couldn't find any way to replace that w/o replacing the whole thing. Any ideas?
First you need to resolve what is causing tearing as that is not a common/natural wear spot. Clearly it is rubbing on console trim (lots of sharp plastic pieces and angles there).
Then, remove entire e-brake assembly (v simple - 4 frame hold down nuts, an e-brake cable tensioner bolt, and wire sensor clip). Find good local upholsterer (automotive preferably but it's small enough any will do) and they will be able to repair / replace covering beautifully - even dying some stock leather to match if need be.
Good luck
"Cool Prius!"
- Nobody
