Old 07-30-2023, 05:15 AM   #1
particlewave
Originally Posted by noboi4 View Post
Hey, let me level with you man.
i haven't finished it yet, but if you want, you can try what im doing. almost the exact same issue. 986 2000 boxter S, arctic silver.
p04110 and p1411, vacuum leak repair got rid of p1411. now, im sautering a resistor in place of the injection output sensor, to make the ecm (hopefully) not give the code.
as far as im aware, the intended voltage is 1.5V.
the good delete kit, (that wont give a code) is a lot more expensive than a resistor and a suatering iron.
This will end badly.
It's spelled "soldering", by the way. I don't think you should be doing it.
particlewave is online now   Reply With Quote
