Old 07-24-2023, 03:38 AM   #3
Starter986
1998 Boxster Silver/Red
Just got done with this same project. You are correct about not being able to get a torque wrench in there!
Inner bolt and nut need to be tightened with the car on the ground. If you can't do it that way, at least get a jack under the hub and lift the hub up to put a load on the assembly.
Like you, I ended up torquing the inner bolt and nut as tight as I possibly could.
Does anybody read the posts? Dude said, in 2017, he had the car on ramps when torquing.
Ramps. Ground. Ramps. Ground.
Anyone see the connection here?
lol
1998 Porsche Boxster
