Old 07-20-2023, 01:29 PM   #1
rastta
rastta's Avatar
2000 Boxster S race car
$18k OBO I have tons of pictures so please PM me if you want a Dropbox link to them.
So I put a new used motor in at the end 0f 2021. Had issues to sort out which meant it didn't get the install finished and motor started until April of last year. I sat on it for a couple months and got it running again to take out for a track day in January of this year. However. I had some smoking issues and decided not to run it. It had old gas in it so I drained flushed and filled it up and the smoking was much better but it's still there. Replaced plugs and 02's and it hasn't gone away. Compression tested motor and all good 230+ in all cylinders. When compression testing it - I noticed one plug seemed gas soaked or wet or both. Replaced the injector but no luck.
So at this point - I'm simply have no desire to keep the car and throw more money into it. As you can see by the ad below - I put a ton of new stuff on it expecting the motor to be good - over $17k invested last year. Also prior to it originally dying at the end of 2019 I had redone a bunch of stuff which maybe has a dozen track days on the stuff done in 2018 including the suspension rebuild.
I also have a 20 ft. Featherlite trailer which I've extensively modified to include storage, a monitor, tools, wheel rack, and a solar charging and battery system. I'd sell that along with car for an additional $30k OBO.
This is a great opportunity for someone to build an almost new car for under $35k. The Motec System and Motons alone are worth over $15k.
2,538# total weight w/o driver
Engine
• 2003 3.6L 996 M96-03 motor purchased from Specialty German with 42k miles and installed by Griffin Motorwerke April 2022
• The Following items were installed new on the engine prior to installation:
o Rear Main Seal (RMS)
o LN Engineering IMS
o FVD deep sump oil pan and baffle
o New Porsche Motorsports Air Oil Separator
o All new AOS hoses
o New spark plugs
o All new intake plenum and exhaust gaskets
o New water pump and low temperature thermostat
o Remanufactured Bosch White Injectors
o All new heat sleeving of fuel and other lines
• MoTeC Engine Management - M820 ECU with Logging, dual lambda, active cam, e-gas and full custom harness
• Custom Dyno Tune by RaceTune in June 2018 on 91 octane. Dyno Sheet available
• Custom sealed double feed air box with K&N filter
• New coolant temp and crank position sensors in Dec 2017
• New coilpacks in Dec 2017
• Remanufactured Bosch starter installed in Dec 2017
• FVD Exhaust headers Borla Race Mufflers with 3"exhaust (approx. 97 dB)
• 3" Supertrapp tips and 3" muffled Laguna turn downs
Transmission
• AASCO Motorsports flywheel (machined and rebalanced in 2017 and new friction surface installed in April 2022)
• Used 6 Speed Transmission with 42k miles installed by IPB Autosport In January 2019
• Guards Transmission (GT) LSD GT2RPro 4340 Chromoly LSD 80/50 Lockup
• New Numeric Shifter and cables in April 2022
• Rennline Aluminum custom shift nob
• Tarret Shifter Risers
• New Sach Performance Clutch and disc and new throwout bearing and sleeve in April 2022
• TuneRS Transmission Oil Cooler and pump kit with -10 AN lines.
Suspension
• OEM GT3 27mm - 5 way adjustable front bar with Tarett Engineering extended front drop links. Heim Joints replaced July 2018
• 19.75mm - 2 way adjustable Tarett Engineering rear bar with Tarett drop links. Heim Joints replaced July 2018
• Moton 15 position Double Adjustable Motorsport Remote Reservoir Shocks - Rebuilt by Performance Shock in July 2018. Shock dyno available.
• Mode Front Camber Plates - serviced with new spherical bearing in July 2018
• Front Wheel bearings replaced with FAG bearings in July 2018
• Sway bar bushings replaced front and rear in 2016
• Inner tie rods and boots replaced in June 2016
• FVD Motorsport aluminum front strut tower brace
• New Eibach Main Springs 700 pounds front, 800 pounds rear installed in July 2018
• Rennline Rear Subframe Stabilizer With Tie Downs (Front also has custom tie downs)
• Elephant Racing front Lower Control Arms installed July 2018
• Elephant Racing rear toe links installed July 2018
• Rear lower control arms, rear forward arms, front A arms, rear toe arms replaced Aug 2012
• All new OEM or hardened bolts were used during suspension refresh in July 2018
Wheels
• 2 full sets of Enkei Performance NT03+M (One set new in November 2018. Both full sets are shod with NTO1's 245/40 and 275/40 f/r.
• Front - 18x8.5 and Rear - 18x10
• Race studs front and rear
Brakes
• Stock calipers and rotors (Front calipers rebuilt in 2016 with new seals/boots. New seals and boots for rear calipers to be installed)
• Pagid Yellow RSL1 front pads and Black RS19 rear - one day on new pads
• Motul 660 fluid
• Goodrich Braided steel brake lines
• Custom brake duct intakes with direct feed from front with hoses and custom fittings on wheel hub
• ABS switch on dash to turn ABS on or off
Interior
• All new 250 amp fuse panel with integrated relay system and wiring.
• All new Carbon Fiber dash insert with toggle switches
• Custom windshield wiper switch with Gretsch knob
• Kirkey Ultra Shield race seat
• Driver seat rear seat brace
• New Schroth 6 point Hans compatible race harness
• Schroth window net
• Schroth right side driver net
• Momo alcantara wheel with quick release hub and radio button
• Custom carbon fiber dash inserts
• 3" dual custom driver air ducting from front cowel
• MoTeC SDL Dash logger with data port and MoTeC i2 Standard Data Acquisition
• Longacre drink holder and bottle
• Video camera mount
• Cool Shirt System with custom made cooler and in dash pump switch
• Motorola Communication system with radio holder, antenna and wiring. Complete pit radio system included.
• Rennline perforated pedals and dead pedal
General
• Full CroMo 1.75" welded in cage with padding for driver
• MoTeC GPS Antenna for start finish laps and Google Earth race line overlays
• AMB Transponder
• 3 Jet Fire Bottle FE-36 Fire Suppression system with full tank 2022
• Lexan windscreen with Tearoff cover and vinyl screen.
• Custom Lexan rear window
• James Lister & Sons 52mm Air jacks (3) with spares
• Cup Car Solutions SpeedWand trigger airjack air control wand
• New Odyssey battery in 2017
• 0 ga positive and negative battery cables for entire car with new copper ends and new OEM alternator/starter cable in 2016.
• GT3 Cup fiberglass front nose with center radiator with custom radiator and brake ducting
• Fiberglass front hood
• Custom engine cover with dual integral fans (switch on dash)
• Custom side scoops that provide air to the intake and oil cooler/starter
• Front side radiator fans can be turned on and off with a switch on dash
• Ultra light fiberglass roof (no liner) and factory attachment points
• Fiberglass front light replacement covers
• Single custom windshield wiper
RACE CLASS
PCA Class GT3S
POC Class R3
NASA Class GT3S
rastta is offline   Reply With Quote
