Old 05-17-2023, 11:14 AM   #7
LoneWolfGal
LoneWolfGal's Avatar
Originally Posted by LoneWolfGal View Post
My next move is to give Pelican a call, describe the problem, and see if I'm on the right track. And find out the valve's official name.
I called Pelican and talked to Glenn in parts, but he couldn't help me without a part number from the valve. At any rate, before I buy the valve I need to make sure the problem isn't just a plugged or leaky hose to or from the valve, which I understand is fairly common. A defective hose from the valve to the intake was forum member Luckyman01's problem, I believe. If it turns out the purge valve itself needs to be replaced, Glenn said none of the valves are all that expensive, and that was music to my ears.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
