EZ Pop Off for Ball Joints
If you can get clam shell in maintenance mode. Its easy to use a long pry bar (the kind with a nail head remover end) and pry off the ball joints as noted elsewhere. First, remove clip in the photo, then, use the pry bar to remove RED ball joint to release the top. Next, pop off the BLACK ones to release the clam shell. As others have shared, the top them comes up and down smoothly and the clam shell lays down without need for latch. In maintenance position this process took less than five minutes and will me buy time to fix the problem.
Reason: Adding photo
