Old 05-03-2023, 11:26 AM   #1
Starter986
1998 Boxster Silver/Red
Leaking down from the top on the left side and mixed with coolant... My guess is that it's the oil cooler. There are four O-rings that seal it to the block.
Here's a pic from Pelican Parts:
...also a big picture.
As sson as I saw the big pic... lol. That was rich, thank you.
OP... I believe 78F is correct. I'm thinking there isn't really much else to describe what it could be. Before you get the car in the air... leave it on the ground... and replace the cooler O rings. If you're in a pinch I can mail you an extra set I have. I went withh the S cooler... and purchased two sets off those rings. Let me know. Orr, hit O'Reiily/Autozone/NAPA and pick those rings up in short order.
If I were a betting man... oil/coolant... left ide... coming from top... I'd put my money n those rings. Quick fix, and not complicated. Plus, time is money... and you should be going with the least expensive fix, first.
Keep us posted.
1998 Porsche Boxster
