Old 01-20-2023, 12:02 PM   #5
nuvolari
Originally Posted by Sveach756 View Post
Don’t waste your time or money. Get the UAOS with track drain. It will never fail and allows you to run a higher oil level that ends up draining back to the block via a modified oil fill tube.
Ha, but their pricing is comical!
Originally Posted by pilot4fn View Post
The updated version is this 'return tube' as lower item on the picture below.Original 'swirl pot' in the top one.
I am just now comtemplating should I change those, but am not really certain is it worth it.
Yeah, I'm not sure either. Trying to get Lee Jenkins answer on facebook group but I can't find the part numbers to reference and now I can't find any mention of them online. If I get an answer from him, I'll post here. I'm sure either version will work and probably won't kill your engine. Or, consequently, maybe it will. Who knows with these engines...?
The the breakdown is that the swirl pots reduced aeration of the oil but slowed oil return. The 997 return tubes return oil faster in theory allowing for more oil to be available at the pick up tubes. The 997 tubes bolt right in and are considered an upgrade. You would add a windage tray if you’re concerned about aeration.
Hmmm, good to know. I wonder if using one of each would be an option? One 997 to allow quick oil return and one 996 to help aerate part of the oil. I guess it could cause unknown issues with oil pooling on one side of the engine and affecting our tender little M96 engines.
Geez, these engines make you double think everything....
Thanks for the answers.
Does anyone have the part numbers for the 997 versions?
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
