Old 10-18-2022, 02:05 PM   #12
Homeoboxter
Originally Posted by nuvolari View Post
Well I’ve heard how the center bolts are a weak spot and I’m having trouble getting my bearing out using an internal puller. So I might need to pull it using the center bolt and that has been known to break when using it to pull the bearing.
As for the flange, mine has some pitting on the surface that goes inside the bearing. I know that’s not spinning and merely holds the center race of the bearing but still it’d be nice to replace.
So you’re using two bearings in your car? I was actually thinking of doing that or trying to find a dual row bearing with one row of roller bearing and the other with ball or conical to support the thrust. Of course, with one look at bearing catalogs, I gave up on that! Those catalogs are not pleasant or easy to navigate for the layman!
Do you have a thread on your installation? I’ve read many of your threads and seen your helpful comments on other threads but I haven’t seen anything about a two bearing setup.
Anxious to see the details….
It`s a weak spot when you use it for pulling the bearing or when you overtighten the nut on it. Otherwise the load on the center bolt is very low in the 2 row application. There`s lengthy thread is in the show&tell section.
