Old 10-16-2022, 07:42 PM   #8
piper6909
piper6909's Avatar
Originally Posted by Frodo View Post
Not sure...do the electrical approaches to this problem still work if the battery is totally disconnected? Ie, there's no longer any complete circuit? Maybe, I don't know..
In any case, if you need to do the mechanical approach, this will give some guidance..
Help! Disconnected battery, closed hood - jumper method doesn't work!
In theory it should still work. The battery cables only complete the circuit with the battery. If you connect an external power source to the fuse box terminal and a good ground, then you'll have a complete circuit to that external power. I'm guessing the real question is how many amps does the release solenoid draw? Dghii said he had good luck with another car battery, but not with a charger. Maybe the charger he used charger can't handle the draw from the solenoid. My guess is that it may draw around 5 amps.
2010 Subaru Forester
