Old 09-05-2022, 12:51 PM   #1
flmont
Code po440,small leak in evap,.. And..
GM Gent's I have a few questions about my 02' 2.7 boxster,..1. that 440 code says small leak in the Evap system, can I assume that that's a fuel system leak of some sort.
2. lately after a gear change and clutch fully released I get a little hesitation,could that be a result of probably needing new chain guide pad's my last Deviation number's are 3.75 and 8.75,..and I do have that nasty startup noise,.very briefly but very noticeable.
Now for the curious question's,.is it impossible to install the 6sp trans from a 2000' Box S into my 2.7,..and can I also use the Mo30 suspension system from that same car,.?? I have the car with a blown engine,..or is it better to install another engine and put the car back on the road,.?? Thank's Very much for any info that you would share..Frank
flmont is online now   Reply With Quote
