Old 08-01-2022, 03:47 PM   #1
rastta
rastta's Avatar
That's a great idea. I've pulled the center... the foam repair job... and am thinking you could remove the guts... the flaps... cut a hole or two in the hood, and ram-air it. It seems that could give a nice breeze, when moving. Likewise pulling the cabin filter and ducting it to a ram-air on the hood.
I put two vents in my Boxster with hoses to the interior from those vents. You don't need to do any scoops - the air gets sucked in well enough. It uses 3 in hose. The ducts were from here and required no modifications other than to drill the holes in the factory screw locations.
https://www.pegasusautoracing.com/productselection.asp?Product=3623
rastta is offline   Reply With Quote
