Old 07-07-2022, 09:08 AM   #12
Frodo
Apologies for not meeting your timeline.
What I should have said is that if you are going to use it rarely, an inexpensive one will get the job done, but once you have it you may end up using it more than you expected and a higher quality one may be worth the cost.
If I do end up using it more than I expect then you will be correct, I will regret not getting the Uview. I somehow just don't think that'll be a problem. Time will tell.
No apology needed, you got around to it.
