Old 07-02-2022, 10:27 AM   #1
jaykay
jaykay's Avatar
Okay so the objective here was to get at the regulator to see what was going wrong. Can I assume that all tension adjustment is used up in this mechanism given the position of the spring loaded fitting to the left or is there’s some fix other than a crappy tie wrap? What’s going on here is the green fitting can be pulled straight out and one can see a lot of slack in the cable system. Unless I can put a tensioning device in there somehow, the whole regulator has to be changed from what I can see. Any recourse here to save me pulling the glass and regulator?
986 00S
