Old 06-11-2022, 05:15 PM   #4
bg305
01 Seal Gray 986 S
bg305's Avatar
Originally Posted by elgyqc View Post
Have a read through this
Door window not dropping properly – a troubleshooting check list.
My issue was cracked solder joint in the latch mechanism.
This is an amazing write-up, thank you for putting it together! I think I am going to find a similar issue to yours, I noticed when I opened the door up and was reaching in to try to unplug the microswitch that jostling the wires caused the window to move up and down as if I had pulled on the door handle.
I will go through this and add anything I find to your thread to keep everything together there.
bg305 is offline   Reply With Quote
