Old 06-06-2022, 11:39 AM   #11
jax944
Originally Posted by elgyqc View Post
You don't seem to be getting much help, so here is my 2 cents worth. Get an OBD reader, even a cheap one might give you some indications of what is going on. Try starter fluid in the intake (remove the air filter for access?). Pull a spark plug to see if you have a spark. Engines still run on 2 things, fuel and spark... plus the will of the electronics gods... which depends on a few thousand other things.
Thanks for the suggestions. I have completed both of them and will do it again tomorrow. I am also removing the spark plugs and putting my finger over the opening to check for suction/pressure but unfortunately I have to enlist someone to turn the key lol. I will keep updating the thread.
jax944 is offline   Reply With Quote
