Old 05-08-2022, 09:53 PM   #11
ike84
Ike
That is a little nasty.
Is there paint cracking at the lower right portion of the dent? on a ridge?
If you pull that dent pull just a little then tap your crowns (pressure ridges) down.
Sometimes they don't move by tapping. but tap them anyway.
Then pull a little more and tap the crowns down over and over.
The idea is to release pressure in the area of the damage.
All the pressure is in the crowns(ridges).
You want to watch the crowns (ridges) the most.
You want them to soften and start to flow toward the low area of the dent.
If you pull up to much low metal to fast it will put more pressure on the crowns (ridges).
Then things will get worse.
Softening the crowns and getting them to start flowing towards the center of the lowest area is the
most important concept to understand.
You want to pull in a way that it helps to open up the crowns release the pressure and allow the crowns to drop and flow towards the lows.
Plan every pull to help do that.
Then help the crowns along by tapping.
Warm the area up with a heat gun it will soften the paint and help keep it from cracking.
It will also make the metal move easier. Keep the metal warm while working on it.
Thanks for the advice blue. That was my plan - work my way from the outside in along a circular path, with a masons hammer near by for some gentle persuasion. The part along the window will be the most difficult I think, hopefully I don't break it. It's ok if I do, that gives me a reason to get a new window with the doggy door in it like I've always wanted lol. I'm not going for perfect, just enough to be able to Bondo and then she needs a new paint job.
Ironically enough, the cedar 8x8s that held up the barn which crushed the truck are being repurposed - they will make fine cross members for a flat bed! That way, not only did she survive the beating, but she got something out of it lol.
Sent from my SM-G970U1 using Tapatalk
