Old 04-10-2022, 03:27 PM   #1
wwjd
Originally Posted by ike84 View Post
I have Firehawk in my low beams and acuma in my high beams. Install is a bit of a trick because the retaining latch won't seat over bulb base. You must remove the retaining latch, position it around the bulb base, install the light, and then reseat the retaining latch. You'll understand what I mean when you do it. Other than that though there is no modification necessary and I really like them. They absolutely have their drawbacks (light pattern, cri, etc), but the new ones are far better than the first generation.
Sent from my SM-G970U1 using Tapatalk
Thanks, and interesting. So, if I want the best lighting coverage, perhaps I should stuck with the halogens? sounds like the LED light pattern not as good?
I'm not going for a look, just great, bright night driving, thought LED might be better
2002 Porsche Boxster
wwjd is offline   Reply With Quote
