Old 01-07-2022, 03:36 PM   #2
JFP in PA
Originally Posted by elgyqc View Post
I am ready to install the new bearing but I have been putting it off while I ponder whether to replace the flange with the new model that has a ribbed seal in place of the o-ring. As I understand it the only advantage is less chance of an oil leak. Up to now the old o-ring flange has worked for me in 3 different engines.
I could also replace the IMSB centre bolt with the improved one that comes with the Pelican kit... as far as I know it is not available as a separate part so I would have to buy the whole kit just to have the bolt. Is the failure of the original bolt really an issue?
No, but failure of the sealant on the bolt causing oil leaks is...............
