Old 10-31-2021, 07:06 AM   #10
Boxstard
Originally Posted by feedback View Post
I think you have to first see where your car sits and see if you need the adjustment. I will be on or close to the bumpstops when I need it to have maximum contact and alignment. As everyone seems to get different readings at minimum and max spec I would decide when you get the car setup and if you cannot tune the alignment then buy whatever adjustable parts you need then. If I need to get LCA’s I’m going to simply go with the SPL pro series, but I’m hoping I can get away with top plates and stock adjustment.
With 2” lowered, I got 1.7 deg camber, maxed out with stock mount/ LCA, while 2.6deg rear as minimum out of stock LCA all the way in. You need adjustable rear toe arms at this ride height to get zero toe, and bump steer spacer keeps the arm parallel to LCA.
Front bump steer rods made noticeable difference for me, steering wheel is more stable over rough surface with little kick backs, and it feels really smooth from turn-in through the corner, that may also come from zeroed out toe front and back.
For now I’d live with stock LCA and see how my tires wear for my driving, but if you lower the car beyond 0.5” (Euro M030 spec) then you probably be better served with adjustable toe arms, if not with bump steer feature.
