Originally Posted by Ben006
Well, mine doesn't rub because the throttle is where is was stock. No above the starter solenoid wich makes it too high.
you can not reuse the stock intake tube if you go to a bigger throttle body.
Now that some time has passed. Any luck with some dyno runs? Curious to see the numbers. Definitely interested if theres some good gains and they come back in stock.
