Old 09-08-2021, 04:11 PM   #3
PaulE
The way your pictures posted I can't see anything, they are very large and blurry. But I can tell you that the Litronic projector lens is real glass, and because of that I doubt that they are turning cloudy. If you take the back access panel off the headlights, I think you can remove the projector by removing 4 security Torx screws. You need the bits with the hole in the middle to clear the post in the middle of the Torx screw head. Harbor Freight sells a cheap set of these. My guess is that the issue is with the 3M film on the outside of the headlights.
