Old 09-06-2021, 10:20 AM   #2
KevinH1990
KevinH1990's Avatar
Dennis Vogel: Projects - Boxster Heated Seats
Check this web page (see Section II -Disassembly) for instructions on removing the seats. The only additional guidance I have to add is:
1. You should remove the seat retaining bolts before you disconnect the battery. This will allow you to move the seats back and forth to access the bolts.
2. If Dennis doesn't mention it, you should open the top. (Obviously, you will then need to store the car inside or cover it well until you can reinstall your seats and reconnect the battery.)
3. You can remove the seats yourself, but if you can find a helper that may prevent a back strain.
Good luck
