Old 08-22-2021, 05:11 PM   #11
El Fabricante
Originally Posted by wwjd View Post
pretty thick fiber washers. tried one, still happend, tried another one and the ABS lamp turned on, and the sound was the same. Was going to pull the sensor out and tape over the hole, but guessing it would still sound. shop didn't think it was bearings, but I suspect it's that reluctor ring messed up and I can't get to that - lacking tools, skills, jack stands etc.
You need a shim that matches the mounting face of that sensor. Shine a light in the ABS sensor hole and look inside to see if the ring is damaged.
Here's what my shim looks like: https://i.ebayimg.com/images/g/qQsAAOSwVwNg2F7S/s-l1600.jpg
El Fabricante is offline   Reply With Quote
