Thread: Code P0103
Old 08-16-2021, 08:42 AM   #7
JFP in PA
As MAF codes generally clear themselves once the fault that triggered the code is repaired, you may be overlooking the obvious: P0103 is the code typically caused by a wiring issue, which has not been mentioned as having been identified or repaired. If the problem is still there, so will the code be.......
