Thread: Code P0103
Old 08-15-2021, 04:41 PM   #2
blue62
Originally Posted by Race View Post
After cleaning the MAF and checking all vacuum lines seamed to cure the no idle issue and the car 2001 S starts idles and seems to have good throttle response. Yet I am still pulling a P0103 Code I have not had the chance to drive the car yet, my question is, will this code clear with driving and time? or should I consider a new MAF? I just bought the car and it had many issues due to lack of maintainece I am thinking it was not driven much and left outside to the elements.
Thank you
It would be better if you clear the code with a scanner.
That way if the MAF is still an issue that code will come back.
If you clear the code and it does not return then your MAF is ok.
Any scanner that can read that code should be able to clear it.
