Thread: Remove air box
Old 08-10-2021, 06:51 AM   #1
blue62
If you have a Durametric I believe you can toggle your individual injectors on and off with engine running.
So if you toggled an injector off you could see it in RPM drop and the engine would sound different and idle different.
You would at the least know the injectors were getting signal from the ECU and working.
