Thread: Remove air box
Old 08-09-2021, 10:58 AM   #1
gabedrummin
gabedrummin's Avatar
Remove air box
So you can remove the air box with out removing the motor .Pulled exhaust at header. Pulled sway bar .Pulled transmission mounts .Pulled bolt from front engine mount a lowered motor till it touched cross member. At this point i was able to fish it out the top . My car was previously de-snorkeled . I can now get to bank 2 injectors . How can I check the injectors with an ohm meter ? Thank you all
gabedrummin is offline   Reply With Quote
