Old 08-05-2021, 05:23 PM   #2
blue62
Originally Posted by Race View Post
Hello I just purchased a 2001 Boxster 3.2 the mileage is 90k plus I do not think it has had any service other than occasional oil change now and then in the past 5 years. The muffler has been removed to make it sound "cool" Yes it is getting a new exhaust system, But it will not idle. The car starts fine tries to idle then you hear a click similar to a relay and the car dies like it ran out of fuel. This all happens in about 5 or 10 seconds after starting I have recalibrated the idle circuit. And have not pulled any codes yet. I plan on replacing the fuel filter and spark plugs. Once you start the car and feather the throttle it is possible to keep it running and even drive the car seems as long as you keep it above 2500 rpm you can keep it running. Looking for suggestions on where to start.
Can you tell where the click sound is coming from????
Cabin?
Engine bay?
Rear trunk??
Any chance the click is the air conditioning clutch kicking in????
Turn your climate control system completely off. Then try starting the car and see it it will run with the climate control off.
What shape is the battery in??
What shape is the alternator in?
You could start with changing the #1 and#2 relays.
#1 is the DME/ECU relay
#2 is the the fuel injector ignition coil relay
They are around $12.00-$15.00 at any auto parts place.
They are a common relay.
Pull any codes it may have in memory
List them here
Try the things I listed above
Let us know results
blue62 is offline   Reply With Quote
