Old 08-04-2021, 08:28 PM   #9
Viper10000
You might be able to load the lift onto your trailer with the castors if you have a winch and then remove the 4 posts and lay them down. Worse case would be removing the runways and posts and then loading everything on the trailer. If you can load it up while assembled, taking the posts off for travel wouldn’t be too difficult. And all of the cables would remain in place and not need to be re-routed. How big is the trailer, width and height? And does it have a winch?
Viper10000 is offline   Reply With Quote
