The height from the floor to the top of the runway is measuring 70 1/8 inch resting on the top lock. The max height before the cylinder bottoms out is 73 1/2 inch. 108 less 73.5 is 34.5. 13 inches too tall. If you set the lift on the 4th lock from the top, you are at 53 1/2 inch under the lift and floor to top of runway is 58 1/8 inch. That’ll give you a bare 50 inches from runway to ceiling. Is the Boxster shorter than the vette? I can take some more measurements if you’d like, maybe with the lift sitting on different locks? As for loading it on a trailer with the castors, I think it would be possible but not comfortable. Also you would be around 9 feet wide. I don’t think that is legal to tow with something hanging off the trailer that wide.
